No, you would just have to provide the club name. It’s not an unreasonable ask in this forum as I have been asked to provide proof in this forum before. The real reason however is that you know that I have been an AMA member for 45 years and I have never witnessed what you describe. As an “ exalted AMA competition flier “ I spend many hours at the field. Not as much as I used to. Now knowing your personality here, I have to make the assumption that your situation could have possibly happened after some provocation from you. I recall you once complaining that you went to an AMA field and nobody approached you while you were there. So it stands to reason that on a different occasion you were approached and came off with the same all knowing AMA sucks attitude that you have here and were treated in kind.
And please stop bringing your boat organization into these conversations. They are apples and oranges. A boat has less of a safety aspect to members and spectators, That is unless you’ve seen one fall from the sky at 100 mph. Continuing to bring boats into the conversation only makes you less believable.
