RCU Forums - View Single Post - Dual Water Outlet Mod Walbro h20 pump
Old 11-01-2024 | 12:16 PM
Hydro Junkie's Avatar
Hydro Junkie
Originally Posted by XtremeAerobat
hello, I know it’s a long shot as this thread is so old but I can’t find any more info. I have this same pump and would like to add a 2nd outlet to it so I can have one supply the cylinder and the other supply the exhaust manifold. Does the additional outlet go on the same “level” as the original one?
What kind of boat are you planning on installing this in? Generally speaking, nitro and gas fueled boats don't really need a pump since water is pushed through the cooling system by the boat moving forward. The exception to this is if the boat has a clutch so that it can stop while the engine is running. A clutched boat, when sitting still, doesn't have any pressure pushing water through the cooling system unless it has a pump to pull water into the system
