RCU Forums - View Single Post - Seagull Gee Bee Z
Old 11-04-2024 | 10:31 AM
  #752
skystar
Originally Posted by Rerge
I went with a 12s setup. I think I went with a pretty light setup, not sure how everyone is getting such a light build. Mine is right at 14lbs and it is a handful to control on the ground. Flight characteristics are good, the most unsettling thing is cutting throttle removes almost all of the tail control, so just dont be choppy with it. My setup is centered around the sound more than anything.
I did widen the landing gear about 6in to give it more ground control. Works much better, way less tippy.
Wont let me add the link yet but here is everything but the https portion
youtu.be/HF8CwOJ4zi8
Hello, thanks for the replay, do you have more info over motor esc and lipo/and bec system you use? and do you have an picture of the landing gear modification? I think I will do that also. The sound is great! what is youre flight time?
Greetings
