RCU Forums - View Single Post - Seagull Gee Bee Z
Old 11-06-2024 | 08:48 AM
  #757
Rerge
You will not need to worry about balance with that motor. It is actually a bit on the heavier side. Just make sure you play with the motor placement a bit to bring the motor in as much as possible. Your single 6s will be fine inside the aircraft.
Should be fun!
