RCU Forums - View Single Post - FB Jets Panther
Thread: FB Jets Panther
Old 12-13-2024 | 04:49 AM
Malcolm H's Avatar
Malcolm H
Default FB Jets Panther
I’m refurbishing one of these that was acquired without gear doors fitted.
The outer main gear door is opened and closed by a link to the gear oleo. Manual shows a pic with the retract half removed and the link connected to the oleo and the door but the angle the pic is shot at doesn’t show how this link is attached to the oleo.
Would be grateful if someone with one of these could explain how it is attached? Is the oleo drilled and tapped to take the ball link or some other method? Would also like to know the height up from the hinge line to the attachment point on the outer door?
Thanks in advance,
Malcolm
