RCU Forums - View Single Post - Hanger 9 Super Stick Question
Old 11-16-2003 | 10:30 AM
DTB's Avatar
DTB
My Feedback: (15)
Default RE: Hanger 9 Super Stick Question
Thanks Scale Dreamer, did you remove rudder material or Elevator material. What travel numbers are you using (mm or inches)?
ORIGINAL: Scale Dreamer
I did a Super Stick 40 not long ago. I did remove a little material to allow for more elevator travel. As a matter of fact, I flew it on high rate elevator all the time. I just wasn't comfortable with the throw on low rates.
My tank was junk and it "blew a leak" the first time I filled it up. Trashed it and got another. Just was not worth the trouble.
A tip for flying this plane: Don't hold in a lot of up elevator while taking off. Doing this will actually "HOLD" the plane down on the ground. Instead, at about 3/4 throttle while the plane is approachong rotation, give a little up elevator and she rises up nice and smooth instead of straight up.
Just my .02 worth
John
