RCU Forums - View Single Post - BJ Craft Muscle Cloud Build
Old 02-03-2025 | 06:23 AM
J-P
Additional informations about the MUSCLE CLOUD
Wing span is 177 cm
Weight ready to fly 4960 g with an AKIBA battery 5200 mah weighting 1030g
CG varies from 220 to 240 mm from the lower wing dowels
Rudder servo is installed in the fuselage in front of the lower wing trailing edge
Rudder authority is very important and airplane just need a touch of on knife edge
The height of the battery plate is very important to achieve a rudder to aileron zero mix
Elevator horn length is 13mm.
Aileron horn length is 20mm.
For the prop selection, seems large diameter give the best results 23, 23.5 or 24 / 20 F&R
The height of the fuselage to compare with the LEADER G can be see on this pic with the difference size of the strutsQuick struts have already been developed and tested and will be offered in the future. It’s a kit to assemble
Wings fences are included in the kit and related with spin entry only according BJ
“ It shall be necessary for thin air, high altitude flying field, or heavier nose heavy setting
In Europe where temperature is lower than in Asia for example, it shall not be needed.
Japanese pilots do not use it so in Europe as well.
But may be needed in Singapore or Zhuhai. "
LEADER G & MUSCLE CLOUD STRUTS
