Originally Posted by
speedracerntrixie
Reduce and modify just the tip airfoil. By cutting a foam core wing, the airfoil will transition along the wingspan so in affect you are changing the entire wing.
Sounds good. Would you have the pattern for the stock tip, as I have nothing to start modifying at this point. Thanks!
