I received my 1.8m Matrix from Banana Hobby. I've been so impressed with the 2.2m version that I wanted to try the smaller version.
I ordered it turbine ready because I like the Pilot servos and this actually a good value.
So far, the build from the factory is very good. The servo arms are quality aluminum with turn buckles and ball end joints. The hardware is top notch.
The model came with a 2l fuel bag installed. Its a permanent installation. Removal will require cutting the carbon rods out. I would have liked to change the fuel tubing out. But accessing the bottom of the tank to do this may not be possible. I assume this is what the factory pilots use and will give it a go.
I have two pontential engines for this aircraft - a X60 and X120. The 60 is minimum power but reduces the weight by 500g or so. The 120 is greater than needed, but is close in weight to most 85's.
Assembly should be very quick as all I need to do is mount the equipment to the deck and plug it in.
One piece fuselage
Front tray is meant for batteries
Fuel bag is standard now.
Wing mounting clips are on the bottom now.
