Originally Posted by
Mudgee
Shouldnt need that much to hold KE
You may be experiencing blow back on the servo - may need a servo with a bit more grunt
ok thanks,
if i need more throws ill have to go with a different servo arm which is not an option.
After some fiddling i was able to get 50mm rudder throws on each side.
The manual only says max throws, hence.
