if its a hollow molded wing, neatly remove the paint from around the perimeter of where you plan to do your work, remove the lower skin using an angled cut in the center of the area you removed the paint from, then do whatever internal beefing up you need, then just reattach the lower skin and glass over the seam that you cut.
