Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Composite ARF revision questions >
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 04-03-2025 | 11:23 PM
Default Composite ARF revision questions
Hi to all!!!
I recently picked up a Cermark/Topgun composite spit never assembled. After reviewing the build threads it seams to be extremely weak where the retract rails are mounted (numerous posts about guys ripping retracts out and having to rebuild)
Ive been building off and on for 35 years, balsa mostly, then standard covering or fiberglass then paint. I’ve never worked with composite materials. So my question is if I peel back the bottom of the wing to rebuild the landing gear rails and beef them up what do I need to do to patch her back up? Can I use my standard method of balsa sheet, then fiberglass mat and resin? Thanks in advance!
Old 04-04-2025 | 01:09 PM
speedracerntrixie's Avatar
My Feedback: (29)
I’m not familiar enough with that specific plane to advise without pictures of your starting point. If you can post some I will take a look and see what I can come up with along with product recommendations.
Old 04-07-2025 | 01:32 PM
invertmast's Avatar
My Feedback: (23)
if its a hollow molded wing, neatly remove the paint from around the perimeter of where you plan to do your work, remove the lower skin using an angled cut in the center of the area you removed the paint from, then do whatever internal beefing up you need, then just reattach the lower skin and glass over the seam that you cut.
Old 04-09-2025 | 01:55 PM
Speed racer,
There’s a thread on here that shows one of the members cut into the rear part of the fuselage to install a pull-pull tail wheel and rudder…..
I tried to post pics, but I guess I haven’t posted enough to earn the “PRIVILEGE” to do so…..
Old 04-09-2025 | 01:59 PM
After digging into the wing I’ve found the wing is balsa built, balsa sheeted and covered in what looks like Oracover. The fuselage is maybe a fiberglass mold. There’s a thread on here (Cermark Spitfire) that shows one of the members cut a patch out of the rear of the fuselage to install a pull-pull tail wheel and rudder……
I tried to post some pics, but they wouldn’t go through. Thanks!
Drew
