RCU Forums - View Single Post - Composite ARF revision questions
Old 04-09-2025 | 01:59 PM
Drewcampbell1963
After digging into the wing I’ve found the wing is balsa built, balsa sheeted and covered in what looks like Oracover. The fuselage is maybe a fiberglass mold. There’s a thread on here (Cermark Spitfire) that shows one of the members cut a patch out of the rear of the fuselage to install a pull-pull tail wheel and rudder……
I tried to post some pics, but they wouldn’t go through. Thanks!
Drew
Originally Posted by invertmast
if its a hollow molded wing, neatly remove the paint from around the perimeter of where you plan to do your work, remove the lower skin using an angled cut in the center of the area you removed the paint from, then do whatever internal beefing up you need, then just reattach the lower skin and glass over the seam that you cut.
