RCU Forums - View Single Post - 1/3 scale Spacewalker Build
Old 04-16-2025 | 08:41 AM
Tony Hallo
The plans should show the line of thrust, level the fuselage to the line of thrust and then use your incident meter to check the incidence. Positive incidence indicates the leading edge is higher than the trailing edge. Make sure to check side to level as well.
VincentJ (04-17-2025)
