RE: Capiche 50
Seems there is some hope then...
IH Hinges.. basically what you do is deflect the hinge when its in place and wick small doses of thin cyano into the corner of the hinge / surface. You should be able to watch it wick in. Its had enough when you get a small bit of cyano left sitting in the corner which you wipe away. When you are used to the hinges you know when to stop.
I know it does not help Sprink, but you could not have used enough syano... I have NEVER had a failure, even after a crash, with these hinges which I have used for 10 years or so, and I NEVER drill holes or do anything special like pinning etc.
As for the pictures for the comp, they are all eligible and my feelings about the spinner and prop are irrelevant... Im not the judge... its the IH Wives that are doing the judging... totally impartial !
Personally... Sprink... yours is one of my favourites... even though it is not particularly original (same as mine !) I like particularly the underside and the way you put the stickers on the fuz upside down.. simple but effective.
But like I say... my view point doesnt count !
