RCU Forums - View Single Post - Problem with ESC
Old 05-25-2025 | 12:52 PM
ColinW
Default Problem with ESC
Hi, I have a problem in getting an ESC to run the motor.(i have tried 3 different ESCs with the same result). I have a SX 26 and a T6L Sport. I bound the 26 to a 7108 and a 6 ch R3106GF and the T6l to the 6 ch rx. I then tried to use a brushed ESC to drive a brushed motor. In all cases the ESC powered the rx, but there was no power to the motor when operating the throttle. I switched to a Spectrum 6 Ch and after moving the throttle a few times the motor burst into life. I tried this on the Futaba with no joy and also tried switching on with the throttle and trim at max and min. Still no movement. Any thoughts - as I must be doing something wrong. Thanks. Colin
