Thanks BlacCat
Appreciate your response. Adrian sent the conversion parts but did not install or run my 325. I have had no good fortune with it this far. I am considering going back to the glow carb and methanol. I have messed with the walbro till frustrated. Worked with Adrian to no good solution. Hope yours is working to your satisfaction.
Hey Brutus, if your still out there, are you using the stock glow carb on your 325? And does exhaust pressure ( via a tap on the exhaust ring) provide enough pressure to run it without the APS pump?
Thanks guys
Aaron- (Hyjinx)
