RCU Forums - View Single Post - Is This Normal?
Thread: Is This Normal?
Old 07-29-2025 | 07:09 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
I don’t see anything alarming other than the corrosion. If the manifold leaks when you run it, put a little RTV around the o-ring (looks like your case is missing the o-ring currently) before cinching the screws down. As long as it doesn’t leak, it should be just fine.
