RCU Forums - View Single Post - Rally car build
Thread: Rally car build
Old 09-01-2025 | 07:02 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
pic time.
I found all the dogbones I needed in my bag of dog bones... but to make them work I had to make the arms 2.5mms longer in the front, and 6.5 in the back(this is due to the axles I'm using in the back).
So the work on the jig was a waste.
Anyways here is the pics so far.
The Front
The back
As can see the one side is missing an axle that is cause I could only find 1. I'm waiting for a pair I ordered expected to come sometime later this week.
Here is how the body looks sitting on it I still need to figure out body mounts setup
As can be seen from the side front to back it is PERFECT for spacing
Width wise it sticks out a TINY bit, but alas it was that or I try to custom make dog bones, and hope they hold up.
Well with what I had to do the rear sticks out maybe 5mm's more then the front, but it isn't noticeable as the body flares in the back, and it was unavoidable.
next to do is the body mounts. I'm not sure if I'm going to cut the pipes on the bottom of the body off
