Hi, is it in this tread or the other one, I'm using edgeTx in a radio master t16s. When you guys talk about changing the curve as you tune, how and where are you doing this? On the radio itself, where the curve is made, and then how do you know which point on the curve are you actually busy with? It sounds rather daunting from what I've read so far.
Also has anyone been able to use pots S1 and S2 to change/manipulate the curve. I've read some have set up a number of curves and then switch to them, does that help, or is it also just a coarse adjustment with fine tuning later? Also read that each engine turns out to have a unique curve, well obviously for different size engines but certainly for the same size?
So far the pot tune I've tried just messes with the whole curve in the "wrong" manner, very new to edgeTx.
I also assume that the Carb curve is always linear?
