Hi Bert,
What I do, is program two curves, on two separate receiver outputs
Do you mean transmitter? The curve I was looking at, is from "raleighcopter" I think, and he's throttle curve is linear? So thats what has confused me a bit
most radios have index marks on the gimbals
It looks like mine doesn't have any marks at all, do you have an example please?
Normally, I start out with the fuel curve set at full fuel all across the entire range.
Do you mean here that the "solenoid" is fully open while you adjust the needle setting on the carburettor itself?
The throttle curve is a one time affair, I usually do not touch it once set.
So once this is done, you then adjust the solenoid curve?
Each curve has as many points as there are index markers next to your throttle stick
I was going to use the 9 originally recommend, but the index markers makes more sense, EdgeTx can do up to 17 points, but I'm sure that will be too fine and fiddly?
Sorry if I'm repeating some things and being a pain but my brain has a strange logic, and I'm sure once I actually get down to it, it will jump into place.
Many thanks
