RCU Forums - View Single Post - Glo to Gas conversion: how to get it right fast !
Old 09-25-2025 | 10:19 PM
  #113
1967brutus
Originally Posted by Tony Hallo
Why not simply have your radio play the value of the throttle stick? Special function, play value, throttle, every 5 seconds. Assign it to a switch so you can turn the function off when not needed.
It will play the value -100 to 100 and you will have the exact value.
I think that is what I said?
Originally Posted by 1967brutus
You can try making a temporary (or more permenent) index yourself, or you can perhaps do your testruns with the stickpositions "on screen"? Another option is to use the call-function, where activating the momentary switch (the one that springs back when you let go of it) to audibly call out the stick position.
I use that function all the time. Standard I set it up to call out engine temp (or RPM and temp combined) but depending on application, any value I am interested in at that moment. On my tow plane it calls out temp when the towhook is open, and it calls out altitude when the hook is closed (AKA when I am towing, and interested in when to request the glider in tow to unhook).
