RCU Forums - View Single Post - Glo to Gas conversion: how to get it right fast !
Old 09-25-2025 | 11:54 PM
  #115
jorgan
Originally Posted by 1967brutus
If you do, make sure, you set up the TX to call out STICK position, and NOT "throttle position" (the value AFTER throttle curve) or you will be chasing your tail like there's no tomorrow.
I made that mistake once or twice...
Good call, I think in EdgeTx the symbol i have used refers to the stick position. I spent yesterday setting up Special functions so that when switch SB is down, as i move the stick up it calls one, two three etc.. seems to be working. If you pull it back and increase again it repeats the position. Might look at doing a widget, incase i cant hear, with all the noise
