RCU Forums - View Single Post - Ringed glow engine issue
Old 10-20-2025 | 07:13 PM
A. J. Clark's Avatar
A. J. Clark
Take a clean piece of fuel line connected to the vent line blow on the line to see if there is good flow through the line to the carb. I would also remove the filter. Then connect the clean line to the carb. Open needle 2.5 turns and carb barrel fully open blow on the line air should flow through the carb.
