RCU Forums - View Single Post - Resurrecting Kalt Enforcer – where / how can I buy blades?
Old 11-28-2025 | 04:29 PM
4ofN
Default Resurrecting Kalt Enforcer – where / how can I buy blades?
I'm resurrecting my brother-in-law’s 30 year old Kalt Enforcer. I've got everything I need except for the main and tail rotor blades.
I've noticed that a lot of sites have blades listed by model name rather than by spec. Needless to say, 30 year old models aren't listed. Can someone point me to a site where I can buy blades by spec?
I don’t have the original main blades. The main rotor length maximum was measured as the length from the mounting hole that would not touch the tail rotor even if flexed downward. I do have tail blades, but they are chipped so they need replacing as well.
What I need are main blades as follows:
3 mm mounting hole
8 mm root thickness
505 (or shorter?) mm length.
And tail blades as follows:
3 mm mounting hole
5 mm root thickness
72 mm length.
Thanks for any help.
