Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Resurrecting Kalt Enforcer – where / how can I buy blades? >
Resurrecting Kalt Enforcer ? where / how can I buy blades?
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 11-28-2025 | 04:29 PM
Default Resurrecting Kalt Enforcer – where / how can I buy blades?
I'm resurrecting my brother-in-law’s 30 year old Kalt Enforcer. I've got everything I need except for the main and tail rotor blades.
I've noticed that a lot of sites have blades listed by model name rather than by spec. Needless to say, 30 year old models aren't listed. Can someone point me to a site where I can buy blades by spec?
I don’t have the original main blades. The main rotor length maximum was measured as the length from the mounting hole that would not touch the tail rotor even if flexed downward. I do have tail blades, but they are chipped so they need replacing as well.
What I need are main blades as follows:
3 mm mounting hole
8 mm root thickness
505 (or shorter?) mm length.
And tail blades as follows:
3 mm mounting hole
5 mm root thickness
72 mm length.
Thanks for any help.
Old 12-11-2025 | 08:48 AM
Rafael23cc's Avatar
I went to two of the vendors that i usually visit when i need parts. They list the blades by size.
https://www.helidirect.com/collections/main-blades
https://www.amainhobbies.com/main-bl...icopters/c2210
If you click on the blades you are interested in, they should give you the rest of the information you are looking for. Let me point out that "root thickness" should not be an issue, as most blades come with spacers that are inserted in the grip to take up the slack if there is any.
Rafael
Old 12-11-2025 | 01:21 PM
Rafael
In my case, the root thickness is important as my rotor head has a max 8mm root whereas a lot of blades of the appropriate length are 10mm so I need to be careful.
I'll check the links you posted to see if they have something I can use.
Thank you for the info.
