RCU Forums - View Single Post - Resurrecting Kalt Enforcer – where / how can I buy blades?
Old 12-11-2025 | 01:21 PM
4ofN
Originally Posted by Rafael23cc
I went to two of the vendors that i usually visit when i need parts. They list the blades by size.
If you click on the blades you are interested in, they should give you the rest of the information you are looking for. Let me point out that "root thickness" should not be an issue, as most blades come with spacers that are inserted in the grip to take up the slack if there is any.
Rafael
In my case, the root thickness is important as my rotor head has a max 8mm root whereas a lot of blades of the appropriate length are 10mm so I need to be careful.
I'll check the links you posted to see if they have something I can use.
Thank you for the info.
