RCU Forums - View Single Post - MidWest AT-6 Texan Plans built not a kit
Thread
12-31-2025 | 09:55 AM
13
SCrawford
My Feedback: (
1
Aug 2003
57
1 Post
Walnut Hill, FL
Left Outboard wing section
I laid out the hand cut ribs on the spruce spars and the went back and set and glued all the ribs. I started from the outboard rib #20 and worked inboard to rib #11. I then glued in the trailing edge and then leading edge. Upon gluing the trailing and leading edge I then built the incidence jig. Utilizing the jig, I glued in rib #10. The incidence from the jig turned out to be a bit much. After measuring the incidence, it turned out to be 5 degree so I adjusted it back to 4 degree and when clamped to wing look much better than 5 degree.
Laying out the ribs
Beginning to glue in ribs
Glue in leading and trailing edges
The incidence gauge
Setting rib #10
fitting the outboard wing and lining up the holes for a wing tube.
Reply
Like
SCrawford
View Public Profile
Send a private message to SCrawford
Find More Posts by SCrawford
View iTrader Profile
