RCU Forums - View Single Post - Home made YJ Jeep
Old 01-06-2026 | 03:57 PM
JulliPolas
Originally Posted by SyCo_VeNoM
didn't see a reply as I had other things going on. The lift isn't as high as it looks as the axles were on a bit of a slant as I took it while sitting on my laser cutter which has like a 10 degree slope. I do wish I could go lower, but if I go any lower it won't really have any articulation so it
Side note it is finished I made the side marker lamps out of clear petg,and I just got to take a picture
It is possible, Adjusting the length of the links will rotate your axles to the right angle. Just that will lower the shock's mounts on the axle and lower the lift. Shorter shocks will help too. The links parallel to the ground or close will improve performance . And lower center of gravity beats too much flex
