Originally Posted by
jaka54
Your engine is more than enough for that airplane provided you prop it right and use 5-10% nitro fuel.
Best props are Graupner G Sonic, RAM or APC. Stay away from white tipped Master A props! 13x8 or 14x6 is what I would use. And most important ...build the plane light! Remove as much wood you can and use the lightest possible wheels and use a 240-300cc tank. Not more!
Not sure where you are located. I am near Detroit, MI.
If you feel your Supass is a bit low on power I would be willing to help out a bit. I have a ring and bearigs on hand. Should put some bounce back in the old OS. If you care to send the engine I can go thru it and return it in a couple of weeks.
I do have references if there is any concern.
Glad to help, enjoy the new plane.
