RCU Forums - View Single Post - BH Twister
Thread: BH Twister
Old 01-27-2026 | 07:39 AM
H5606
The tank bay was sheeted with cross-grain 3/32" balsa and the landing gear legs clamped in a bench-vise to adjust for a lower front end stance.
Pencil lines laid out on fuselage using a straight-edge and circle template gives boundaries to follow when removing wood in an effort to lighten things.
A Dremel with carbide burr was used to make the initial cutouts followed with a drum-sander and Permagrit tools to sneak up to the lines -
Tank bay sheeted over after moving gear mounting plate to new location -
Stock landing gear stance -
Bending gear widen and lower L/G stance -
Modified gear stance -
Boundary lines laid out ahead of cutouts to remove material weight -
Fuselage belly laid out ready to make cuts -
Belly cutouts -
Belly cutouts -
Carbide burr cuts to stay inside lines -
Over-wing hatch cutouts with carbide burr -
Followed with drum-sander -
