RCU Forums - View Single Post - Hirobo Lama 35b helicopter conversion,Gas to electric power.
Old 01-29-2026 | 06:25 AM
airwalk
Before I did all this work on building my own electric motor conversion parts,I looked for a conversion kit available for the Hirobo lama. I was told that there was one made years back,and was no longer available. Some people said they liked it and some did not.Any way it would have saved me a lot of work of building my own! So the only thing was to build the electric motor set up myself. Anyway back to the build. The next step was to build the motor mount plate. I used a K&S aluminum.64 thick sheet. I had to draw out the mounting holes locations on the plate. after this was done I could then mount the aluminum plate to the bottom of the motor mounting plate. The complete motor was inserted into the bottom of the helicopter. Then aluminum channel was laid across the bottom of the motor plate for added support. Everything was bolted into place. Some spacers were used for spacing between the motor plate abs channel supports. I hope the pictures might give you a better idea on how this works. More to come!
