It is very easy!
With the piston and connecting rod installed to the crank shaft you slide/push the cylinder liner over the piston and into the crank case! Simple like that! The cylinder liner is chamfered at the bottom so all you do is push the cylinder liner over the piston ring and it will slip in with out problem!
