RCU Forums - View Single Post - Binding Problems
Old 03-24-2026 | 05:49 PM
mrcoolpop
Default Binding Problems
This is really confusion; I have a Flex Innovations Super PNP Series Plane. I have the NX10 Transmitter. When setting it up I pick the Aircraft I select Model Type, Aircraft Type and select Dual Ailerons because I have 2 separate channels. I am binding it to the AR631 Receiver. One ailerons is on 2 and the other channel 6. After binding the receiver channel 6 aileron does not work. If I used another servo in that same channels (6) it works or if I use a y -harness it works. Question: Why the servo in the plane does not work after it is bind?
