Airplanes - All types View all types of airplane ads here. Includes Kits, ARC''s, ARF''s, and RTF
Binding Problems
Old 03-24-2026 | 05:49 PM
Default Binding Problems
This is really confusion; I have a Flex Innovations Super PNP Series Plane. I have the NX10 Transmitter. When setting it up I pick the Aircraft I select Model Type, Aircraft Type and select Dual Ailerons because I have 2 separate channels. I am binding it to the AR631 Receiver. One ailerons is on 2 and the other channel 6. After binding the receiver channel 6 aileron does not work. If I used another servo in that same channels (6) it works or if I use a y -harness it works. Question: Why the servo in the plane does not work after it is bind?
Old 03-25-2026 | 08:55 AM
look at your channel assign menu and make sure it shows channel 6 for the 2nd aileron.....sometimes the RX assigns its own channel for the other surface............
Old 03-25-2026 | 09:56 AM
BarracudaHockey's Avatar
Or just the servo monitor and see what's moving when you move the stick
Old 03-25-2026 | 01:03 PM
Yep......that works too........if all is right....BAD SERVO??????
