RCU Forums - View Single Post - Help with Plane Identification
Old 05-11-2026 | 08:22 AM
mgnostic's Avatar
mgnostic
Originally Posted by Bijhy
Thank you so much for the additional information Matt. That gives me a good starting point to do some more in-depth research. The blue green one is completely sealed up. The only thing that's removeable is the engine cowling. The entire wing and fuselage is sealed so if there are any repairs to be made you'd be out of luck without a major structural rebuild.
I'll let you know if I uncover anything interesting.
Any idea on the engine with the "ORONE" marking. Googled it and didn't get any returns.
There was a "Drone" brand of engine where the stylized D could be mistaken for an O but they were primarily diesels. They had a distinctive cone shaped cylinder head. As far as the green plane being sealed up that is the way is was usually done. No radio gear to access, small enough to toss in a car in one piece and the control line gear really didn't need much maintenance.
