RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 11-17-2003 | 05:22 AM
  #1906
Sprink's Avatar
Sprink
Default RE: Capiche 50
Quick update:
Wing now repaired. Will post photos tonight if they are any good. Top spar was broken but cleanly, so easy to repair. Just hope it is strong enough. Bottom spar was ok, but had unglued itself from the central bracing, so that was re glued. couple of cracked ribs, and the top sheeting was broken, but that was it.
I'll start on the fuz tonight. Gives me a chance to reposition the tank. It was still back in between the wings, where it was supposed to be with the pump. I took the pump off, but did not move the tank forward, and there was no muffler preasure either. Amazing the amount of suction that the Saito 72 develops. Was having to run it very rich though.
Yes, i did use thin CA on the hinges. I've done some silly things in the past but not that one [&:]. Looks like i didnt use enough. I'll go over the elevator and ailerons again just to make sure on them.
Archie, I didnt take a nice photo of the underside, but got the old ones so will send one of them to you as well (want all unfair advantages that I can get)!
And thanks everyone for your kind words.
