RE: Capiche 50
Its a shame they have to crash at all..
seems that the model is that impressive its pushing the pilot to go beyond their means in some cases... Weve had a few customers come back for a second kit having totalled the first one pushing the envelope, but they have enjoyed the model so much and learnt so much more that they simply want to throw another together... and I spose you could probably half the build time second time around..
with those hinges carefully tile the bottle at an angle that you can flow the cyano to the join slowly but steadily and keep going til it stops wicking in and you get a little bubble of glue left. Then clean it off. If you get a little bubble of glue straight off it likely to be due to the covering so you just bend the hinge back a little to open up the gap and away it will go.
Dont give up on them sprink... cyano hinges really do work..
BTW, WHERE exactly do you store your cyano..?
