RCU Forums - View Single Post - AeroFly & Reflex with RFG2 USB Controler ?
Old 11-18-2003 | 11:41 AM
Simon35
Default RE: AeroFly & Reflex with RFG2 USB Controler ?
AFP MAY work as they also use a joystick compatible input. The Reflex won't work with the Interlink as they depend on a pure TX generated PPM signal. That medal has two sides: NO, you can't use any joystick device such as game commander or G2 interlink. They think that you should train on your real tx as that's what you would face on the field, that's where all the mixing happens and that's where you find your special switches. It's not funny if you train auto's with a switch on your left and you have to think in the field where that switch is in your real radio ....
Cheers - simon
