AeroFly & Reflex with RFG2 USB Controler ?
I want to use a USB dedicated controler (don't want to use my personal real TX), but I prefer the realistic flight of REFLEX or AeroflyPRo to the RFG2 software. Seems that they behave more like a real plane (for 3D funfly training)
Do you know if REFLEX or AeroflyPRo will work with a realFlight G2 USB INTERLINK controler ?
thank you all
thank you all
AFP MAY work as they also use a joystick compatible input. The Reflex won't work with the Interlink as they depend on a pure TX generated PPM signal. That medal has two sides: NO, you can't use any joystick device such as game commander or G2 interlink. They think that you should train on your real tx as that's what you would face on the field, that's where all the mixing happens and that's where you find your special switches. It's not funny if you train auto's with a switch on your left and you have to think in the field where that switch is in your real radio ....
Cheers - simon
Cheers - simon
