RCU Forums - View Single Post - CA Hinge vs. Robart
Old 11-18-2003 | 06:33 PM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: CA Hinge vs. Robart
ORIGINAL: CafeenMan
ORIGINAL: rajul
ORIGINAL: CafeenMan
My point was that the leading edge of a control surface is radiused. A proper hinge will be centered at the center of radius. You can't do that with a CA hinge which means it is fundamentally in the wrong place. But like I said, for the most part it's not an issue. I just find it a lot easier to drill holes than to try to cut slots and keep them all lined up.
If you ever saw any of my planes you would see that every control surface is dead-aligned with the flight surface that it's attached to.
Aaaahhhh....now I see your point. Thanks. From my observation, most people who use robarts or kletts still have their pivot point in the same position as ca hinges.
Maybe a diagram will help explain better
