It might work, but instead of bolts, try using screws and coat them with something that sticks to the plastic (or better, use a nut from the inside to keep it in place). However, weight might become an issue... Anyway, I'm sure Hobbyzone would probably replace the fuselage if you send them the model and the receipt with a date on it...
PS: i see you're from GA.....if you're near Atlanta, then i can only give you one advice: go to atlantahobby. Their website is
www.atlantahobby.com and Cliff, also a member of this forum (cliffw) will probably give you some helpful hints. He's great with customers.
