RE: pull-pull woes
Thanks about the slack line hint. (However I sense a little 'dead band' near neutral with slack. I'll try again.) Do you get enough throw on the rudder with that setup? I do the same for the elevator which per instructions only needs 1/2" throw (I've got much more) but with that setup I don't get full rudder deflection.
