RCU Forums - View Single Post - Hing Question !!!!!!!!!!!!
Old 11-18-2003 | 11:36 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Hing Question !!!!!!!!!!!!
ORIGINAL: Azcat59
Correct me if I am wrong about this, but as long as a hinge does not shear off at the hinge line, I do not believe there is a lot of force in the direction of pulling the hinge out of its slot. Any thoughts on this theory?
Clair
Under normal circumstances, you're right.
However, there is a circumstance when a great deal of force is placed in that direction.
A lot of emphasis is placed on the "gap". Some people try to get as close to Zero Gap as they can. This is often a mistake. With the control surface too close to the airframe, it can act as a lever; pulling the hinge out of it's slot, or putting undue stress on the flex point.
I say, don't worry so much about the Gap, you can always seal it. Allow your hinges room to flex and your planes will last a lot longer. (Dumb Thumbs not withstanding)
