Fuel Dot Installation
I had a leaking fuel valve and decided to go the fuel dot route. Not desiring to put in a third tank line I went with the T connector setup. My engine now fills with fuel (Webra 120) now and I have no draw when emptying the tank through the fill line. Is there anything I can do besides install the third line? I have a check valve but do not know if that will correct both problems....
