Fuel Dot Installation
Old 05-08-2002 | 09:41 PM
Default Fuel Dot Installation
I had a leaking fuel valve and decided to go the fuel dot route. Not desiring to put in a third tank line I went with the T connector setup. My engine now fills with fuel (Webra 120) now and I have no draw when emptying the tank through the fill line. Is there anything I can do besides install the third line? I have a check valve but do not know if that will correct both problems....
Old 05-08-2002 | 10:30 PM
Caf,
Some suggestions:
1st,when you tried to empty the tank did you have the carb fully closed?
This is by far the best method to date:
Go with the 3rd line to the tank, and put clunk on end. And forget it!!
Old 05-09-2002 | 12:02 AM
MHawker's Avatar
My Feedback: (16)
Hey Daz,
Odd question. I am just about to go the 3rd line route, but was wondering about the clunk. Any chance the two "clunked" lines would get tangled? You know, all that spinning and looping, etc.
Mike
Old 05-09-2002 | 12:08 AM
Mhawker, when you install the 3rd line, just use medium fuel line tubing for both clunks, and no tangles will happen. Daz...
Old 05-09-2002 | 12:20 AM
Without the third line all you can do is clamp off the tubing between the T-piece and the carb. Hemostats (long tweezer like things with a locking mechanism) reaching in through a cooling intake hole are good for this.
Old 05-09-2002 | 08:20 PM
Thanks for the replies. Tearing the tank out....what a pain. Will go the third line route. I am worried about the tangling. Do I make the third line clunk line shorter?
Old 05-09-2002 | 08:36 PM
caf2461, if your worried about tangling. Spread the brass tubes on the inside of tank apart slightly, and again use med fuel line, and make both lines able to reach the back of the tank fully.
After assembling your tank shake it around and see, it wont tangle at all, even if you tried to tangle them. Daz...
Old 05-09-2002 | 09:09 PM
Default Double clunk
If you have a brass clunk just solder a piece of brass tubeing to the side of the clunk and then the two lines will always be together.
Sparky
Old 05-09-2002 | 11:15 PM
DLT
My Feedback: (48)
Caf....I can assure you they won't tangle.....if you have a long list of worries, put that at the very end of the list.
Old 05-10-2002 | 10:40 AM
Hobbsy's Avatar
My Feedback: (102)
Default Two lines
I run two lines and two clunks side by side on my Laser 180 V twin and they never tangle, they are not long enough to tangle.
Old 05-10-2002 | 10:52 AM
RCaeroguy's Avatar
I have one of the fuel dots on my trainer. I don't really like it. It has better applications than a trainer, like on a cowled engine but I'd rather unhook the fuel filter and fill that way. Just seems like more potential for leaks. I don't like the idea of the electronics swimming in fuel.
Old 05-10-2002 | 11:27 AM
You really don't need to put in the third line. Just clamp the line to the carb and fill. If your vent is at the top of the tank you won't have a problem. If you are using a check valve on the pressure side, you will need 2 fuel dots. 1 for vent and 1 for fill. This is a common set-up for people using pumped engines.
Mark M.
