ORIGINAL: mikestark
I hopefully will be able to struggle through the list of parts and match them to what I received. My biggest problem is that the instructions I received, there is no mention of control throws for any of the surfaces. My World CAP 232 snaps on elevator application in excess of 35mm, but as this is a 3D, maybe more is required. Where do I start for a safe 1st flight ??
Regards
Mike Stark
_____________________________
Aeroplane Mad !!
Jabiru J450 Full Scale
Sukhoi Su-31 1/3 Scale
J-3 Cub 1/3 Scale
Laser 200 1/4 Scale
Cap 232 1/4 Scale
Sukhoi SU-26 1/4 Scale
Mike,
Did you ever get squared away on the control throws? If not, I can go measure mine for and let you know. Hopefully, you got past the stumbling blocks and are now flying this airplane. Once you do, you will forget about any issues you might have had with building it. I'm ordering a second one for a backup to my first. For a small everyday throw it around the sky airplane, this one is the best I have flown so far. Outstanding power, control response, and 3D abilities.
Stephen
www.GiantScaleRC.com
Also Aeroplane Mad !!
40% Carden Extra 330s - DA-150
Airworld 1/5th scale L-39 - P-120 turbine
BVM King Cat turbine - P-120
Sig 1/4 Clipped Cub/floats - OS160 twin
Balsa USA 1/3rd Scale Cub - 3.2 sachs
1/3rd scale Decathlon - Quadra 75
30% Aeropro Cap 231/ex - G62
3W Xtra-fun - 3W-24
35% Pirate Cap 232 - 3W-100
Hydeout Pattern - YS140
Sig Sm Extra - OS46fx
Sr Telemaster (in progress) - Saito 91
50% Decathlon (kit)
NE Sailplanes Caleb - electric
VIP Pylon racer - electric
Tower Trainer/floats - OS46fx
Sport Air - OS46fx
