RCU Forums - View Single Post - Overpowered?
Thread: Overpowered?
Old 11-21-2003 | 08:32 AM
vinnie
Default RE: Overpowered?
ORIGINAL: Skribnod
Thanks for the info all. I am going to try the flight again this weekend but with little or no elevator at takeoff. I think i need to get more ground speed up. I fly from a grass field wich is kinda bumpy but is 400 feet long. I guess if i get enough speed up it will probably not roll over. I think my problem was pilot error and not the airplanes fault.
Skribnod, I believe you have correctly diagnosed your own problem. Allow a bit more ground-speed before take-off. The .72 should be fine for your plane.
