RE: Guys we need to know everything.
Only trouble with the .25LA is that your planes won't qualify for SSC. And you would be seriously outclassed if you decied to attend a B contest. You may be better off to pick an existing class and go with it. I would suggest SSC. I'm sure you think that .15 size planes with 64" wingspans must be dogs. I would have said the same thing a year ago. These planes fly great! They will perform continuous loops inside or out and are great flyers. You'll probably have to see it to beleive it!
Who knows you might want to come to the Nats or just a contest down the road a bit and mix it up! A real pain if your local rules are differant than the national ones.
Also in SSC you must run a Master Airscrew 8x3 prop.
