RE: Capiche 50
no mix, infact from my copied standard wing set up i had two clicks of down trim. i did play with the engine thrust, think it was pointing up too much and i put a mix of throttle to elevator to cancel some climb! ( yes thick wing it should dive i know ) after i did this i had arrow straight KE and flight.
sadly i didn't get to play much, Choppy had almost as much time as i did lol
i never got to play in calm wind so i couldn't hang it propperly although it tired and was far easier than with the normal wing. the Cougar on the same day i think would have been blown away.
I'm hoping to get back in the air soon, bar the covering the FF wing is fixed. The fuz needs the thrust sorting and then covering.
for those of you that like your funflys, once this test wing has been propperly tested i would highly reccomend it.
